Demo_footer (html file)
Andrew Luger
andrew.luger at daterra.ab.ca
Wed Dec 6 02:24:02 EST 2000
Steve:
Thanks for the quick reply.Not sure it's been mentioned previously, however
with regards to the demonstration installation instructions, the following
change was also necessary, to enable the cached query code to work on NT.
<td><img border="2"
src="/cgi-bin/mapserv.exe?map=[map]&queryfile=c:\inetpub\wwwroot\tmp\DEMO[id
].qy[get_layers]&mode=map&size=200+200"></td></tr>
Not sure that the .exe extension is required after mapserv, but i put it
there anyway to follow prior convention. Had to modify the queryfile path as
well as indicated above. This method works on this system.
Andy
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001206/c41e63d2/attachment.html
