mapserv controls
Stephen Lime
steve.lime at dnr.state.mn.us
Tue Dec 12 15:23:58 EST 2000
You can't use checkbox/radio button syntax with hidden variables. You need something like:
<input type="radio" name="zoomdir" value="1" [zoomdir_1_check]> zoom in<br>
<input type="radio" name="zoomdir" value="0" [zoomdir_0_check]> pan<br>
<input type="radio" name="zoomdir" value="-1" [zoomdir_-1_check]> zoom out<br>
If you really want a hidden variable to hold zoomdir which is set somewhere else, presumably
an initialization script use something like:
<input type="hidden" name="zoomdir" value="[zoomdir]">
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Michael Hearne <Michael.Hearne at noaa.gov> 12/12/00 01:24PM >>>
I have what should be an easy question (but apparently not for me):
When working with the mapserv cgi, how do you set the "zoom in,zoom out,
pan" radio button to default to something other than "Pan"?
Here's what I have in my initial HTML file:
<input type="hidden" name="layer" value="layer1">
<input type="hidden" name="layer" value="layer2">
<input type="hidden" name="zoomdir" value=1 [zoomdir_1_check]>
<input type="hidden" name="zoomsize" value=2>
This defaults to "Pan", where I intended it to come up as "Zoom In".
Any suggestions?
-Mike
Michael G. Hearne email: Michael.Hearne at noaa.gov
Coastal Remote Sensing phone: 843 740-1281
TPMC/NOAA Coastal Services Center fax: 843 740-1312
2234 S. Hobson Ave., Charleston, SC 29407
