Developing uniform mask
Ma
marin at here.is
Mon Jan 10 19:24:48 EST 2000
you can create SHP files from TXT files with FShape. Just put in the text
file the screen coordinates.
URL http://www.javashape.com
You can even add north arrow on the map. Just use TTFont with arrows (from
ArcView or MapInfo).
Ma
imap at chesapeake.net wrote:
> Doug,
> To create a logo with screen coordinates, you need to add a layer to
> your mapfile... something like:
> LAYER
> NAME logo
> TYPE annotation
> STATUS DEFAULT
> DATA "other/logo"
> TRANSFORM OFF
> CLASS
> TEXT " "
> SYMBOL 10
> COLOR 0 0 0
> END
> END
> I think that you need to put this near the bottom of the mapfile
> so that nothing collides with it.
> Notice the directive TRANSFORM OFF is the important part here.
> SYMBOL 10 in my "marker.sym" looks something like this:
> # Symbol 10 - Logo at static position X,Y
> Symbol
> Type PIXMAP
> IMAGE "..\graphics\Logo.gif"
> Transparent 15
> END
> Also, the "logo.shp" layer shapefile has exactly 1 point at the
> correct screen X,Y where it needs to be plotted.
> I hope that helps.
> Chris Stuber (mapsurfer)
> Silicon Mapping Solutions, Inc.
> Doug Nebert wrote:
> > Mapserver community:
> > I am interested in creating a "template" or standard graphic method
> > that would be pasted into every delivered map from a given service
> > (i.e. from a given map settings file). At first I thought I'd just
> > make a GIF with a wld file, but then I realized that I'd need to
> > somehow compensate for its display at all scales, when it is actually
> > more a final mask to put on the delivered image than it is a layer
> > for the mapserver to deal with.
> > This kind of functionality would be helpful in letting someone add
> > a logo, graphic, some text, etc. to a map service to "personalize" it.
> > Can anyone think of a systematic means for accomplishing this?
> > Doug.
> > Douglas D. Nebert
> > Clearinghouse Coordinator
> > FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
> > Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
> 287 Southland Ct
> Dunkirk, MD 20754
