DOS CR/LF in .MAP and .SYM files
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at peligroso.gaiaenv.com
Wed Jul 5 14:59:36 EDT 2000
Hi Daniel and others,
This is a common one (we were nailed by it too when we first began). I
like your idea to modify the parser, but I cannot offer much help. Here
are some alternate pointers for those interested:
* use a decent ftp programme that strips/adds CR to LF (most popular
programmes do this for you)
* don't forget...if you zip the files before transferring, your ftp
prog. will *not* alter the newline characters
* if you are running SAMBA, remember that text files are *not* modified
by default
* use a text editor like UltraEdit (or equivalent) and convert your
files once they are on your SAMBA drive or write your files from ArcView
with only LF (or vice-versa)
* run a script on your files each time they are transferred
* in ksh, run SED (e.g., sed "s/$/`echo -e \\\r`/") [convert Unix LF
to CR/LF]
* in ksh, run SED (e.g., sed 's/.$//') [convert CR/LF to Unix
LF...this assumes all lines end in CR/LF]
I know this is not what you were looking for, but hopefully it may help
some.
Cheers,
Jim
Daniel Morissette wrote:
> Hi,
> Is there any way that the MapServer .MAP and .SYM parser could be
> modified so that it is not sensitive to the difference between DOS and
> Unix linefeeds.
> It looks to me like every new MapServer user goes through the following
> error message when they try to get MapServer running the first time:
> msLoadSymbolFile(): Unknown identifier. ( ):(0)
> or
> msLoadMap(): Unknown identifier. ( ):(5)
> and most of the time, it's because MapServer is running on Unix and the
> .MAP or .SYM file contains DOS ^M chars... either because the original
> file came from Windows, or because a Windows tool was used to extract
> the archive and then copy the files to Unix.
> I'm not a flex/bison expert, so I don't know if it's easy to fix...
> Anyone has ideas?
> Daniel Morissette danmo at videotron.ca
> http://pages.infinit.net/danmo/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
_______________________________________
In order to reduce SPAM (i.e., junk
e-mail), all e-mail to me must include
the following somewhere in the body
of the message: J*I*M
Jim T. Bowen, M.Sc., President
Suite 306, 822-11th Ave. S.W.
Calgary, Alberta, Canada T2R 0E5
Ph: 403-571-7213 Fax: 403-571-7211
bowenj at gaiaenv.com
http://www.gaiaenv.com
