making the server
Stephen Lime
steve.lime at dnr.state.mn.us
Fri May 12 11:07:22 EDT 2000
Sorry guys. This should get easier. Dan Morissette has contributed auto configure
scripts for the next version. They are in the CVS and nightly builds now and seems
to work great.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> John Hockaday <johnh at erin.gov.au> 05/11/00 08:21PM >>>
Ma,
I got the same error after I moved mapserv from one machine to another. I was
able to solve the problem by editing the Makefile and putting the full path name
to the libttf.a library file. Eg.
TTF_LIB=-L./gdft -lgdft /opt/contrib/lib/libttf.a
I hope this helps.
Johnh
> Date: Fri, 12 May 2000 00:25:58 +0100
> From: Ma <marin at hi.is>
> X-Accept-Language: en
> MIME-Version: 1.0
> To: "mapserver-users at lists.gis.umn.edu" <mapserver-users at lists.gis.umn.edu>
> Subject: making the server
> Content-Transfer-Encoding: 7bit
> Hi,
> I got the following error when I tried to initiated the script with
> browser:
> ld.so.1: map.cgi: fatal: libttf.so.2: open failed: No such file or
> directory
> [Fri May 12 18:15:12 2000] [error] [client localhost] Premature end of
> script headers: /usr/local/web/maps/mapserv.cgi
> I have also LD_LIBRARY_PATH=/usr/local/lib:/usr/lib
> What is wrong and how to fix it?
> Ma
