MapServer and XML...
Doug Nebert
ddnebert at usgs.gov
Tue May 16 11:00:37 EDT 2000
Stephen Lime wrote:
> Pretty straight forward I'd say. How does one make the decision between
> making a a parameter a new tag or just having it as an attribute of another
> tag? For example:
> <layer><name>water</name> vs <layer name="water">
Some of it is justa matter of style. I like to put things as properties
on a line when they are almost always present, just to shorten the
length of the file. I like the idea of knowing which named Layer block I
am in expressly, rather than parsing it, though the other form of using
only straight tags works well enough, too.
> Once a DTD is in place a conversion script should be a piece of cake.
There are DTD generators that can use example XML markup to build the
interpreted rules and values. I will look for one and pass the demo.xml
through it. You will need to expland this to include all the various
possibilities of terms within a given group, and other possible groups
that may exist but were not expressed in the demo.map file. You can edit
the DTD by hand to include these.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Doug Nebert <ddnebert at usgs.gov> 05/16/00 08:24AM >>>
> imap at chesapeake.net wrote:
> > Doug, Can you provide a URL reference to the OpenGIS XML topics?
> > I looked thru the list, but no mention of XML on the index page.
> The Web Mapping Service specifies each server's "capabilities" using a
> hierarchical markup in XML for the server and a repeating section for
> each "layer" which is analogous to named layers in mapserv. This
> capabilities.xml file can be placed at a WMS server site for harvest
> into a services registry (so we know what map servers exist) or for
> interrogation by middleware or a smart client to offer layer choices to
> a user. See the WMS Get Capabilities interface specification.
> Also, any day now, the Geography Markup Language (as Recommended Paper)
> will be available for public review. It is not a specification, and
> despite the apparent similarity to a W3C "Recommendation", this is only
> a first step towards a future spec. GML has several flavors of
> implementation, but essentially encapsulates mapped Features, their 0-
> 1, and 2-D geometries, and attributes using XML markup. It is intended
> for use where a client wishes to cache objects for display and query
> without re-visiting the server and could be viewed as a type of export
> format for extracted or full vector data. The next phase of Web Mapping
> Testbed will take GML further towards a specification, but soon the
> recommended paper will be available for you to experiment with.
> > Moving to an XML config is probably the way to go, but guaranteed to
> > break the existing applications that use the old mapfiles. That
> > would be painful to change all those mapfiles I have all over the place.
> > Maybe a mapfile->XML conversion tool would be the ticket... or some way
> > to accomodate either configuratoin as a stop-gap measure.
> Supporting either might be a good idea.
> > I dont know for sure, but I suspect that XML is versatile enought to support
> > all of the baggage we carry in the mapfile. Maybe we can come up with some
> > concrete examples of how this might look? What this boils down to, is nested
> > map objects (and the objects which make up a map) and if XML can support that,
> > it would make perfect sense to persue that goal.
> XML most certainly stores hierarchies of information (think outline)
> with repeated groups, most elements having a starting and ending tag.
> The creation of a "rule" document, called a DTD, would help enforce or
> validate the map file. One quirky thing, but some parsers are very case
> sensitive, so the case of the tags you declare matters... See attached
> example of the demo map file manually converted to XML. Don't
> necessarily trust my assignments, but by defining these rules of
> encapsulation it will make the composition and testing of map file
> contents better.
> Doug.
> > Regards,
> > Chris Stuber (mapsurfer)
> > Silicon Mapping Solutions, Inc
> > 410.257.3187
> > Stephen Lime wrote:
> > > Greetings all. I'd like to start a discussion concerning the relative merits of moving
> > > MapServer configuration files from the ad hoc formats they currently exist in to XML.
> > > Lot's of good reasons to do this, validation being one. Just thinking out loud and
> > > looking towards version 4.0. Comments appreciated.
> > > Steve
> > > Stephen Lime
> > > Minnesota DNR
> > > 500 Lafayette Road
> > > St. Paul, MN 55155
> > > 651-297-2937
> Douglas D. Nebert
> Clearinghouse Coordinator
> FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
> Pager Messaging: http://clearinghouse3.fgdc.gov/dougmsg.html
Douglas D. Nebert
