mapscript query question
Paul Cameron
pcameron at Soils.Umn.EDU
Fri May 19 13:10:33 EDT 2000
I tried running just the query part of the code from the command line and
got the following error:
Can't locate auto/mapObj/queryByPoin.al in @INC (@INC contains:
/usr/freeware/lib/perl5/5.00502/irix-n32 /usr/freeware/lib/perl5/5.00502
/usr/freeware/lib/perl5/site_perl/5.005/irix-n32
/usr/freeware/lib/perl5/sgi_perl/irix-n32
/usr/freeware/lib/perl5/site_perl) at test.pl line 23
I looked around in all the other possible locations perl might have
placed that file and can't find it. I'm running 3.3.007 right now, I'll
grab the newest version and see if that helps.
Thanks,
paul
>What happens when you run it from the command line and feed it a point?
>Also, you don't need the new queryResultObj. That constructor is only
>necessary when reading cached queries.
>Steve
