mapscript Perl module
Zolla Michalak
michalak at hwr.arizona.edu
Tue May 30 12:57:38 EDT 2000
I am using mapserver 3.3 and the mapscript Perl module.
My perl program will not run with mapscript when I open it from a web
browser. It is in the cgi-bin and runs from the web without problem until
I add the line "use mapscript;" where it dies with an internal server
error.
The same program DOES work with mapscript when compiled and run from UNIX,
just not from the web. It think this might be a library path problem.
Before compiling in UNIX, I have to give it this command: setenv
LD_LIBRARY_PATH /local/tiff-3.4/lib:$LD_LIBRARY_PATH. I tried setting the
path in my .login file, but that didn't seem to help. I might have the
syntax wrong though. Here is the setenv line from my .login file: setenv
LD_LIBRARY_PATH /usr/lib:/usr/local/lib:/local/tiff-3.4/lib
Any suggestions?
Thanks -zm
