Utility Questions
Brent Fraser
bfraser at geoanalytic.com
Tue Nov 28 19:04:54 EST 2000
Kieran,
1. Shpinfo is part of the "contrib" directory of shapelib. I'll send you a
copy of the exe file. It seems to work with long file names. (I've used it
on NT 4.0)
2. You can invoke shp2img from a batch file. What scripting language were
you planning to use? You must give it a map file name but you can over-ride
on the commandline some of the map file settings:
The syntax is documented as:
shp2img -m [mapfile] -o [image] -t -l [layers]
There is also an undocumented option to set the extents from the
commandline:
-e minx miny maxx maxy
And an option to substute a different data file for a layer (can be used
multiple times):
-d <layer name> <data file pathname>
Brent Fraser
GeoAnalytic Inc.
#300 , 700 - 4th Avenue SW Calgary, AB
Canada T2P 3J4
Tel: (403)213-2700 Fax: (403)213-2707
www.geoanalytic.com
----- Original Message -----
From: "Kieran J. Ames" <kames at keyspanenergy.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, November 28, 2000 8:09 AM
Subject: Utility Questions
> Group,
> I have a couple of questions that I hope someone could help me with.
> 1. I have a utility called shpinfo, but I can't remember where I got it.
It is Ver 1.1
> 07/15/96
> It seems to have a problem with long file names and I was wondering if
anyone knows of a
> more recent version or an easy work-around (before I re-invent the wheel).
> 2. I'm trying to make small image files on the fly. I'm also trying not
have to maintain
> the housekeeping for small only-used-once map files or waste the time with
the disk I/O
> activity. Can the utility shp2img be called from a script and given
command-line
> parameters instead of pointing to a map file?
> I'm running WINNT 4.0
> As usual... thanks to all for any assistance.
> Kieran
