[MAPSERV] Fonts and porting from Linux to NT.
Chad Streck
chads at adci.com
Wed Apr 18 09:26:44 EDT 2001
Working. Played with the paths some more and what finally worked is
when I used / and did not specify the drive. They looked like this....
helvbold /InetPub/wwwroot/maps/fonts/helb____.ttf
helvbolditalic /InetPub/wwwroot/maps/fonts/helbi___.ttf
helvitalic /InetPub/wwwroot/maps/fonts/heli____.ttf
helv /InetPub/wwwroot/maps/fonts/helr____.ttf
timesbold /InetPub/wwwroot/maps/fonts/timb____.ttf
timesbolditalic /InetPub/wwwroot/maps/fonts/timbi___.ttf
timesitalic /InetPub/wwwroot/maps/fonts/timi____.ttf
times /InetPub/wwwroot/maps/fonts/timr____.ttf
Thanks,
Chad
Chad Streck wrote:
> I have an application that I developed under Linux/Postgresql using
> PHP and Mapscript and I'm now porting it to NT/MSSQL7. I grabbed the
> binaries of php from php.net and the binary dll for PHP_Mapscript from
> dmsolutions. I'm using MSDE for the database server. PHP appears to
> be working well, and Mapscript is giving me an error well after it
> reads in the map file.
> Now that you know the environment, here is what I'm getting....
> *Fatal error*: MapServer Error in msGetLabelSize(): Could not
> find/open font in *C:\inetpub\wwwroot\lib/mapscript.php* on line *202*
> ...where line 202 is a $mapobj->draw(). I believe I changed all the
> paths. I included part of the map file and fonts.list file. I've
> played with the fonts list file to include only single back slashes,
> no quotes and relative paths. This is working fine under Linux. Do
> any of you have an idea of what could be wrong?
> Tanks,
> Chad Streck
> Map file parts..
> map
> extent 263354 548123 967555 1108974
> fontset "C:\InetPub\wwwroot\maps\etc\fontsw.list"
> name "Maricopa County"
> scale 6000000
> shapepath "C:\InetPub\shape"
> size 600 400
> symbolset "C:\InetPub\wwwroot\maps\etc\symbol.sym"
> units feet
> layer
> data "etak\az\county"
> labelitem "feaname"
> minscale 75000
> name "County"
> status default
> type polygon
> class
> color 225 225 225
> outlinecolor 150 150 150
> label
> antialias
> buffer 3
> color 150 150 150
> font "helv"
> mindistance 100
> minfeaturesize 90
> outlinecolor 255 255 255
> position cc
> size 10
> type TRUETYPE
> end
> end
> end
> fontsw.list
> arialbold "C:\\InetPub\\wwwroot\\maps\\fonts\\arib____.ttf"
> arial "C:\\InetPub\\wwwroot\\maps\\fonts\\arir____.ttf"
> helvbold "C:\\InetPub\\wwwroot\\maps\\fonts\\helb____.ttf"
> helvbolditalic "C:\\InetPub\\wwwroot\\maps\\fonts\\helbi___.ttf"
> helvitalic "C:\\InetPub\\wwwroot\\maps\\fonts\\heli____.ttf"
> helv "C:\\InetPub\\wwwroot\\maps\\fonts\\helr____.ttf"
> timesbold "C:\\InetPub\\wwwroot\\maps\\fonts\\timb____.ttf"
> timesbolditalic "C:\\InetPub\\wwwroot\\maps\\fonts\\timbi___.ttf"
> timesitalic "C:\\InetPub\\wwwroot\\maps\\fonts\\timi____.ttf"
> times "C:\\InetPub\\wwwroot\\maps\\fonts\\timr____.ttf"
