[mapserver-users] True Type font
Chad Streck
chads at adci.com
Fri Apr 27 10:00:07 EDT 2001
This may not be too helpful, but you must play with the paths in the
font list. I've pointed all my font paths with full paths, such as....
arial /var/www/html/fonts/arial.ttf
On windows, I do a similar thing, but I had problem with the drive
letters, and had to use forward slashes, so it would look like this....
arial /inetpub/wwwroot/fonts/arial.ttf
Chad
Yeewen Sat wrote:
> I'm having problem using True Type fonts. I get this
> "msGetLabelSize(): TrueType Font error. Could not find/open font"
> error when I define LABEL to use TYPE TRUETYPE. If I just use the
> default Bitmap, the labels show up no problem.
> Please help.
> I'm running mapserver 4.3 on Linux.
> Here's a cut out of the mapfile:
> # Start of map file
> NAME SDB
> STATUS ON
> SIZE 450 450
> SYMBOLSET "../symbol/newsym.sym"
> FONTSET "/web/sdbdev/packages/dv-mapping/fonts/fonts.list"
> EXTENT 10478669.720365 6193732.674832 10521330.299635 6282545.399534
> UNITS METERS
> SHAPEPATH "../data/ywseis4"
> IMAGECOLOR 255 255 255
> # Start of web interface definition
> WEB
> TEMPLATE "../www/java-template2.html"
> MINSCALE 25000
> MAXSCALE 14000000
> IMAGEPATH "../www/tmp/"
> IMAGEURL "/dv-mapping/tmp/"
> LOG "../www/tmp/logfile.log"
> END
> # Start of layer definitions
> LAYER
> NAME dgridt
> TYPE ANNOTATION
> STATUS DEFAULT
> DATA dgridt
> CLASSITEM 'ID'
> MAXSCALE 750000
> LABELITEM "TEXT"
> LABELMAXSCALE 750000
> SYMBOLSCALE 200000
> CLASS
> EXPRESSION /./
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT arial
> FORCE true
> SIZE 10
> ANGLE 405.000000
> POSITION lc
> MAXSIZE 24
> MINSIZE 4
> END
> END
> END
> The fonts.list file looks like this:
> arial arial.ttf
> arial-bold arialbd.ttf
> arial-italic ariali.ttf
> arial-bold-italic arialbi.ttf
> arial_black ariblk.ttf
> comic_sans comic.ttf
> comic_sans-bold comicbd.ttf
> courier cour.ttf
> courier-bold courbd.ttf
> courier-italic couri.ttf
> courier-bold-italic courbi.ttf
> georgia georgia.ttf
> georgia-bold georgiab.ttf
> georgia-italic georgiai.ttf
> georgia-bold-italic georgiaz.ttf
> impact impact.ttf
> monotype.com monotype.ttf
> recreation_symbols recreate.ttf
> times times.ttf
> times-bold timesbd.ttf
> times-italic timesi.ttf
> times-bold-italic timesbi.ttf
> trebuchet_ms trebuc.ttf
> trebuchet_ms-bold trebucbd.ttf
> trebuchet_ms-italic trebucit.ttf
> trebuchet_ms-bold-italic trebucbi.ttf
> verdana verdana.ttf
> verdana-bold verdanab.ttf
> verdana-italic verdanai.ttf
> verdana-bold-italic verdanaz.ttf
> Please help.
> Thanks.
