[mapserver-users] mapplet without complete refresh
Kralidis, Tom
Tom.Kralidis at CCRS.NRCan.gc.ca
Fri Aug 3 11:00:42 EDT 2001
Armin,
Using the mapplet's swap() method will do this. However, you must control
the coordinate calculations on the client (i.e. JavaScript), as well as
other applicable MapServer variables.
MapServer's CGI version handles these issues (irregular bounding box fitting
to mapwidth/mapheight, etc.).
I believe Steve has an application which does this in the Gallery section of
the MapServer website, called "LandView", however it's quite a job to
implement it. Perhaps a HOWTO document idea?
Has anyone else got hints?
Thanks
..Tom
Tom Kralidis
Systems Scientist
Canada Centre for Remote Sensing
Tel: (613) 947-1828
http://www.ccrs.nrcan.gc.ca/
> -----Original Message-----
> From: Armin Burger [mailto:armin.burger at territoriumonline.com]
> Sent: Friday, August 03, 2001 8:58 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] mapplet without complete refresh
> In the mail archive I found in a posting that it should be
> possible to use
> the mapplet and avoid a complete refresh of the entire page.
> Only the applet
> contents should be updated by zoom actions etc. This should
> be done with
> some JavaScript functions. Can anybody tell me how to do
> this? Is there an
> example in the gallery collection?
> My problem is that I want to change parameters like 'mode' or
> 'zoomdir' via
> JavaScript (with buttons), and with every complete refresh
> these parameters
> are reset to their default values. Maybe there's also another solution
> writing always back the current parameter settings to the
> refreshed page. I
> assume it could be done with some dummy html page containing
> all necessary
> form parameters that will be read and written into the
> refreshed page via
> javascript. Is this approach feasible?
> It could probably also be done with frames but I'd prefer a
> solution without
> them.
> Thanks for any hints.
> Armin
> Armin Burger
> Territorium Online
> Siemensstrasse/Via Siemens 19 - 39100 Bozen/Bolzano - Italia
> _
