[mapserver-users] Mapplet problem - first time user (FWD)
Kralidis, Tom
Tom.Kralidis at CCRS.NRCan.gc.ca
Fri Aug 3 11:31:48 EDT 2001
The "image" parameter tag of the applet contains a hostname which is not
kosher.
Do you have the right hostname to your box? You can use the "[host]"
MapServer variable in your template.
Also, if you are accessing remote layers, applets cannot access resources
from outside the machine on which they are hosted.
Hope this helps.
..Tom
Tom Kralidis
Systems Scientist
Canada Centre for Remote Sensing
Tel: (613) 947-1828
http://www.ccrs.nrcan.gc.ca/
> -----Original Message-----
> From: teb [mailto:teb at mallit.fr.umn.edu]
> Sent: Friday, August 03, 2001 10:31 AM
> To: mapserver-users at lists.gis.umn.edu
> Cc: robbrown99 at hotmail.com
> Subject: [mapserver-users] Mapplet problem - first time user (FWD)
> ------------- Begin Forwarded Message -------------
> X-Originating-IP: [213.122.116.162]
> From: "robert brown" <robbrown99 at hotmail.com>
> To: mapserver-info at lists.gis.umn.edu
> Subject: Mapplet problem - first time user
> Date: Fri, 03 Aug 2001 11:48:18 +0000
> Mime-Version: 1.0
> X-OriginalArrivalTime: 03 Aug 2001 11:48:18.0152 (UTC)
> FILETIME=[2FE39E80:01C11C12]
> Hello all,
> I am trying to get the Mapplet working and have followed the 'How
> To' page. However, when I initialise the template file, the user
> interface appears and I
> think the applet gets accessed (there are no messages saying that
> it is not being accessed), but I get this message in the browser
> message bar:
> exception: com.ms.security.SecurityExceptionEx [mapplet.init]:
> cannot access "(my_host_name)": 80
> I checked the access settings (I am using PWS on Windows '98),
> and the folder I have the mapplet.class in is accessible. Does
> the mapplet work with
> PWS, or only on a 'real' web server? I would be very grateful for
> any suggestions on this problem. Thanks for your time.
> Rob Brown
> ------------- End Forwarded Message -------------
