[mapserver-users] Using PostGIS with MapServer
Paul Ramsey
pramsey at refractions.net
Fri Aug 3 14:48:23 EDT 2001
Here is a brief description of a LAYER entry using PostGIS
(http://postgis.refractions.net) as a spatial data source:
PostGIS provides a SQL interface to large sets of spatial data. The
'CONNECTIONTYPE' is 'postgis'. The spatial data is stored in tables as a
column alongside the attribute data. Correspondingly, for MapServer to
build a PostGIS layer, it needs to know:
- What database to connect to (CONNECTION)
- While table to get the data from (DATA)
- Which column in the table holds the spatial objects (DATA)
- Any extra filtering information used to subset the data to be
displayed (FILTER)
The database connection is governed by the a 'connection string' which
is a standard set of keys and values like this (with the default values
in <>):
"user=<username> password=<password> dbname=<username> host=<localhost>
port=<5432>"
An empty connection string is still valid, and any of the key/value
pairs can be omitted. At a minimum you will generall supply the database
name and username to connect with.
The connection string goes in the 'CONNECTION' parameter of the LAYER
object:
CONNECTION "user=dbuser dbname=gisdatabase"
A complete SQL query which pulls a windowed subset of spatial data from
a PostGIS database might look like this:
a) SELECT
b) geom FROM roads
c) WHERE
d) geom && 'BOX3D(1423141 1512324 1513214 1652151)'::box3d
e) AND
f) type = 'highway'
When Mapserver pulls data from the database, it constructs this kind of
query. Parts a, c and e are just syntactical. Part d is derived from the
current extents automatically. Parts b and f are supplied in the map
file, in the 'DATA' and 'FILTER' lines of the layer definition
repectively. The example below gives a complete layer, with filtering
and expressions: note that the expressions in the CLASS objects do *not*
use SQL logical syntax, they use Mapserver's internal syntax for
describing logical comparisons.
LAYER
CONNECTIONTYPE postgis
NAME "widehighways"
# Connect to a remote spatial database
CONNECTION "user=dbuser dbname=gisdatabase host=bigserver"
# Get the lines from the 'geom' column of the 'roads' table
DATA "geom from roads"
STATUS ON
TYPE LINE
# Of the lines in the extents, only render the wide highways
FILTER "type = 'highway' and numlanes >= 4"
CLASS
# Make the superhighways brighter and 2 pixels wide
EXPRESSION ([numlanes] >= 6)
COLOR 255 22 22
SYMBOL "solid"
SIZE 2
END
CLASS
# All the rest are darker and only 1 pixel wide
EXPRESSION ([numlanes] < 6)
COLOR 205 92 82
END
END
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
