[mapserver-users] Shapefiles
Richard Ford
mapserver at cubok.com
Tue Aug 14 04:00:46 EDT 2001
> > EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
> Is this extent correct?, you can use the perl script showextent.pl on
> the shape file to see if it is.
> (ie, perl showextent.pl shapefile on the directory where the shapefile is)
[root at localhost risk_data]# perl showextent.pl disslv1.shp
Can't locate mapscript.pm in @INC (@INC contains:
/usr/lib/perl5/5.6.0/i386-linux /usr/lib/perl5/5.6.0
/usr/lib/perl5/site_perl/5.6.0/i386-linux /usr/lib/perl5/site_perl/5.6.0
/usr/lib/perl5/site_perl .) at showextent.pl line 3.
BEGIN failed--compilation aborted at showextent.pl line 3.
I take it, I need to install Map script? I am using Mapserver 3.3.011
Cheers,
Richard.
