[mapserver-users] Shapefiles
Vinko Vrsalovic B.
v at w.cl
Tue Aug 14 13:49:35 EDT 2001
> > > #MARKERSET symbols/marker.sym
> > > #LINESET symbols/line.sym
> > You should set the SYMBOL parameter as shown in the docs.
> Quickly - what do they do?
They define how are the symbols drawn (color, width of lines, etc.)
> I thought leave otu what I do not know to minimise problems. I was
> following the tutorial linked to from the mapserver documentaton page.
If you're using Mapserver 3.3 you don't need to follow my previous advice
(about concatenating the files), just uncomment those 3 lines.
> > > LAYER
> > > NAME "test"
> > > TYPE RASTER
> > is the shapefile of raster type?!?!?
> I assumed it was a raster. It did not load with polygon - but with raster
> the computer churned a bit - but still no display. I will be able to get
> ArcView installed on friday and then see what it is as you say below.
You can try with LINE also (to get this running before friday :) )
> > When I first started with Mapserver I got the same problem, it turned
> > out to be the extent badly set.
> I will try that perl script. I thought if it is wrong, worst case I would
> have a truncated image - or a very small image surrounded by white? Or is
> my understanding of the EXTENT parameter incorrect?
The worst case is a blank image :)
> are keen to get our projetc moving. As such - it always pleases people to
> see progress. And at thsi early stage - great progress and a verification
> of our possible choice in MapServer - would be a display of "some kind!" a
> shapefile by it. :)
If you want, you can send me your shapefiles and I can send you back
a map file that works (or should work) :).
V. <v at w.cl>
