[mapserver-users] Shapefiles
Richard Ford
mapserver at cubok.com
Tue Aug 14 01:11:46 EDT 2001
> > #MARKERSET symbols/marker.sym
> > #LINESET symbols/line.sym
> You should set the SYMBOL parameter as shown in the docs.
Quickly - what do they do?
I thought leave otu what I do not know to minimise problems. I was
following the tutorial linked to from the mapserver documentaton page.
> (concatenate the three .sym files in one and set that file as
> the SYMBOL parameter)
> > EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
> Is this extent correct?, you can use the perl script showextent.pl on
> the shape file to see if it is.
> (ie, perl showextent.pl shapefile on the directory where the shapefile is)
I will try this!
> > #UNITS METERS
> Why not set the units?
Again - keep it simple just to 'see' it load a shapefile.
> > SHAPEPATH "/usr/local/apache/htdcos/lance/risk_data"
> Are this directory and its contents readable by the web server?
yup and all permissions/owenrships are correct for r,w and x.
> > LAYER
> > NAME "test"
> > TYPE RASTER
> is the shapefile of raster type?!?!?
I assumed it was a raster. It did not load with polygon - but with raster
the computer churned a bit - but still no display. I will be able to get
ArcView installed on friday and then see what it is as you say below.
> > STATUS DEFAULT
> > DATA disslv1
> disslv1.* should be in the shapepath directory
Yup. All 3 associated files.
> > I even changed the data to a known shapefile in the ms_demo directory
and
> > copied the same layer definition and I still got a blank box (But always
> > with a working navigation system).
> When I first started with Mapserver I got the same problem, it turned
> out to be the extent badly set.
I will try that perl script. I thought if it is wrong, worst case I would
have a truncated image - or a very small image surrounded by white? Or is
my understanding of the EXTENT parameter incorrect?
> > I will not be meeting the creator of the shapefiles until Friday and I
guess
> > I will need more info about what is inside them to be able to define a
layer
> > to display them? I guess what I really wanted to do was to have a
working
> You can open the shapfile with ArcView, press the info button (the 'i'
rounded
> by a circle) and click on a symbol of the view and you'll see what is the
type
> of the shapefile (polygon, polyline (it should be set as a polygon layer
in the
> mapfile) or line)
As said I will do this. There are so many GIS packages out there, open
source and not. And it has been a steep learnign curve GIS wise. And we
are keen to get our projetc moving. As such - it always pleases people to
see progress. And at thsi early stage - great progress and a verification
of our possible choice in MapServer - would be a display of "some kind!" a
shapefile by it. :)
Thanks for the input.
Cheers,
Richard.
