[mapserver-users] 2 Color(1 bit) tiff files
Alfred Kleva
alfred.kleva at siol.net
Wed Aug 15 12:43:44 EDT 2001
Hi folks !
I have the same problem like Hana. I have tested ms 3.5 on RH7.9 with this
options :
1. ./configure --with-tiff --with-gdal ...
this options do not support classes
2. ./configure --without-tiff --with-gdal ...
this options (use gdal tiff) support classes, but same images do not display
correctly
3. I have added "new" code in "static int drawTIFF" of mapraster.c (see
"case PHOTOMETRIC_MINISWHITE:").
Options are ./configure --with-tiff --with-gdal ...
In my tests it's works OK.
****** TOP ********
static int drawTIFF(mapObj *map, layerObj *layer, gdImagePtr img, char
*filename)
#ifdef USE_TIFF
int i,j; /* loop counters */
double x,y;
TIFF *tif=NULL;
unsigned char *buf;
long w, h;
short type, nbits;
unsigned short compression;
unsigned short *red, *green, *blue;
int cmap[MAXCOLORS];
int startx, starty; /* this is where we start out reading */
int st,strip; /* current strip */
int xi,yi,startj,endj,boffset,vv;
double ulx, uly; /* upper left-hand coordinates */
double skipx,skipy; /* skip factors (x and y) */
double cx,cy; /* cell sizes (x and y) */
long rowsPerStrip;
TIFFSetWarningHandler(NULL); /* can these be directed to the mapserver
error functions... */
TIFFSetErrorHandler(NULL);
tif = TIFFOpen(filename, "rb");
if(!tif) {
msSetError(MS_IMGERR, "Error loading TIFF image.", "drawTIFF()");
return(-1);
if(readGEOTiff(tif, &ulx, &uly, &cx, &cy) != 0) {
if(readWorldFile(filename, &ulx, &uly, &cx, &cy) != 0) {
TIFFClose(tif);
return(-1);
skipx = map->cellsize/cx;
skipy = map->cellsize/cy;
startx = (map->extent.minx - ulx)/cx;
starty = (uly - map->extent.maxy)/cy;
TIFFGetField(tif, TIFFTAG_IMAGEWIDTH, &w);
TIFFGetField(tif, TIFFTAG_IMAGELENGTH, &h);
TIFFGetField(tif, TIFFTAG_BITSPERSAMPLE, &nbits);
if(nbits != 8 && nbits != 4 && nbits != 1) {
msSetError(MS_IMGERR, "Only 1, 4, and 8-bit images are supported.",
"drawTIFF()");
TIFFClose(tif);
return(-1);
TIFFGetField(tif, TIFFTAG_ROWSPERSTRIP, &rowsPerStrip);
TIFFGetField(tif, TIFFTAG_COMPRESSION, &compression);
TIFFGetField(tif, TIFFTAG_PHOTOMETRIC, &type); /* check image type */
switch(type) {
case(PHOTOMETRIC_PALETTE):
TIFFGetField(tif, TIFFTAG_COLORMAP, &red, &green, &blue);
if(layer->numclasses > 0) {
char tmpstr[3];
int c;
for(i=0; i<MAXCOLORS; i++) {
if(i != layer->offsite) {
sprintf(tmpstr,"%d", i);
c = getClass(layer, tmpstr);
if(c == -1) /* doesn't belong to any class, so handle like offsite */
cmap[i] = -1;
else {
if(layer->class[c].color == -1) /* use raster color */
cmap[i] = add_color(map,img, CVT(red[i]), CVT(green[i]),
CVT(blue[i]));
else
if(layer->class[c].color == -255) /* make transparent */
cmap[i] = -1;
else
cmap[i] = layer->class[c].color; /* use class color */
} else
cmap[i] = -1;
} else {
cmap[i] = add_color(map,img, CVT(red[i]), CVT(green[i]), CVT(blue[i]));
else
cmap[i] = -1;
break;
case PHOTOMETRIC_MINISBLACK: /* classes are NOT honored for
non-colormapped data */
if (nbits==1) {
if(layer->offsite >= 0)
cmap[layer->offsite] = -1;
if(layer->offsite != 0)
cmap[0]=add_color(map,img,0,0,0);
if(layer->offsite != 1)
cmap[1]=add_color(map,img,255,255,255);
} else {
if (nbits==4) {
for (i=0; i<16; i++) {
cmap[i]=add_color(map,img,i*17,i*17,i*17);
else
cmap[i] = -1;
} else { /* 8-bit */
for (i=0; i<256; i++) {
cmap[i]=add_color(map,img,(i>>4)*17,(i>>4)*17,(i>>4)*17);
else
cmap[i] = -1;
break;
case PHOTOMETRIC_MINISWHITE: /* classes are NOT honored for
/* ORIGINAL COMENTED
if (nbits==1) {
cmap[0]=add_color(map,img,255,255,255);
cmap[1]=add_color(map,img,0,0,0);
else {
msSetError(MS_IMGERR,"Can't do inverted grayscale
images","drawTIFF()");
TIFFClose(tif);
return(-1);
/* COPYED FROM 'case(PHOTOMETRIC_PALETTE)' and 'case
PHOTOMETRIC_MINISWHITE' */
if (nbits==1) {
char tmpstr[3];
int c;
cmap[i] = -1;
else {
CVT(blue[i]));
else
cmap[i] = -1;
else
} else
cmap[i] = -1;
} else {
else
cmap[i] = -1;
else {
TIFFClose(tif);
return(-1);
break;
default:
msSetError(MS_IMGERR, "Only colormapped and grayscale images are
supported.", "drawTIFF()");
TIFFClose(tif);
return(-1);
buf = (unsigned char *)_TIFFmalloc(TIFFStripSize(tif)); /* allocate strip
buffer */
** some set-up; the startx calculation is problematical analytically so
we
** find it iteratively
x=startx;
for (j=0; j<img->sx && MS_NINT(x)<0; j++) x+=skipx;
startx=x; startj=j;
for (j=startj; j<img->sx && MS_NINT(x)<w; j++) x+=skipx;
endj=j;
y=starty;
strip=-1;
for(i=0; i<img->sy; i++) { /* for each row */
yi=MS_NINT(y);
if((yi >= 0) && (yi < h)) {
st=TIFFComputeStrip(tif,yi,0);
if (st!=strip) {
TIFFReadEncodedStrip(tif, st, buf, TIFFStripSize(tif));
strip=st;
x = startx;
switch (nbits) {
case 8:
boffset=(yi % rowsPerStrip) * w;
for(j=startj; j<endj; j++) {
xi=MS_NINT(x);
vv=buf[xi+boffset];
if (cmap[vv] != -1)
img->pixels[i][j] = cmap[vv];
x+=skipx;
break;
case 4:
boffset=(yi % rowsPerStrip) * ((w+1) >> 1);
xi=MS_NINT(x);
vv=(buf[(xi >> 1) + boffset] >> (4*((yi+1) & 1))) & 15;
if (cmap[vv] != -1)
x+=skipx;
break;
case 1:
boffset=(yi % rowsPerStrip) * ((w+7) >> 3);
xi=MS_NINT(x);
vv=(buf[(xi >> 3) + boffset] >> (7-(xi & 7))) & 1;
if (cmap[vv] != -1)
x+=skipx;
break;
y+=skipy;
_TIFFfree(buf);
TIFFClose(tif);
return(0);
#else
msSetError(MS_IMGERR, "TIFF support is not available.", "drawTIFF()");
return(-1);
#endif
****** BOTTOM ***
Hana wrote :
------------- Begin Forwarded Message -------------
Date: Fri, 9 Feb 2001 9:46:12 +0100
To: mapserver-info at lists.gis.umn.edu
Subject: 2 Color(1 bit) tiff files
I tried to display 2 color's files (1 bit) in different
colors, but unsuccessfully. I have rasters for various
themes (one raster for rivers, second for seats, third for
forest,....) and all are drawn only with black and
white(transparent) color. Maybe I'm doing some mistakes in
code. Please, be so kind and look at it :
This is the raster of forest
LAYER
NAME 'cl2421'
DATA cl2421.tif
TYPE RASTER
CLASS
EXPRESSION "1"
COLOR 0 255 0
END # CLASS
OFFSITE 0
END # LAYER
# this upper example works only in black and white
# I need to do it with the group of rasters ... rivers,
# it works only in black and white , I don't know how to
# change it
LAYER
NAME 'cv2421'
TYPE RASTER
STATUS off
TILEINDEX 'kl50'
TILEITEM RIVERS
MAXSCALE 200000
OFFSITE 0
END # LAYER
Thank you very much. Hana Jirsova
------------- End Forwarded Message -------------
I have tested ms 3.5 on RH7.9 with this options :
correctly
LP Alfred Kleva
****** TOP ********
*filename)
#ifdef USE_TIFF
double x,y;
TIFF *tif=NULL;
unsigned char *buf;
long w, h;
short type, nbits;
long rowsPerStrip;
if(!tif) {
return(-1);
TIFFClose(tif);
return(-1);
"drawTIFF()");
TIFFClose(tif);
return(-1);
switch(type) {
char tmpstr[3];
int c;
cmap[i] = -1;
else {
CVT(blue[i]));
else
cmap[i] = -1;
else
} else
cmap[i] = -1;
} else {
else
cmap[i] = -1;
break;
if (nbits==1) {
} else {
if (nbits==4) {
else
cmap[i] = -1;
else
cmap[i] = -1;
break;
if (nbits==1) {
else {
TIFFClose(tif);
return(-1);
if (nbits==1) {
char tmpstr[3];
int c;
cmap[i] = -1;
else {
CVT(blue[i]));
else
cmap[i] = -1;
else
} else
cmap[i] = -1;
} else {
else
cmap[i] = -1;
else {
TIFFClose(tif);
return(-1);
break;
default:
TIFFClose(tif);
return(-1);
buffer */
we
x=startx;
startx=x; startj=j;
endj=j;
y=starty;
strip=-1;
yi=MS_NINT(y);
if (st!=strip) {
strip=st;
x = startx;
switch (nbits) {
case 8:
xi=MS_NINT(x);
vv=buf[xi+boffset];
if (cmap[vv] != -1)
x+=skipx;
break;
case 4:
xi=MS_NINT(x);
if (cmap[vv] != -1)
x+=skipx;
break;
case 1:
xi=MS_NINT(x);
if (cmap[vv] != -1)
x+=skipx;
break;
y+=skipy;
_TIFFfree(buf);
TIFFClose(tif);
return(0);
#else
return(-1);
#endif
****** BOTTOM ***
