[mapserver-users] Mapplet document.mapserv has no properties
Chan B. Huynh
chuynh at ideorlando.org
Thu Aug 16 14:16:22 EDT 2001
Christine,
I still cannot get to the new url you provided later. It said "page cannot
be display".
However, i went ahead and look at the html template you attached.
Few suggestions you might want to try:
1/ <param name="image" value="http://[HOST][img]"> instead of <param
name="image" value="[img]">
Does your image ever come up without specifing the hostname?
2/ try to put mapplet.class and evalThread.class in the same directory as
the template and see if it works.
3/ not sure what's "applet mapplet document.mapserv has no properties"
means. Was you able to drag a box?
when is this error occurs? Right after you drag a box or after you drag a
box and hit "Enter"?
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of lc
Sent: Wednesday, August 15, 2001 7:35 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Mapplet document.mapserv has no properties
Hello all,
I need help with mapplet. I'm getting the following error message when I
try to drag-zoom:
"Applet mapplet document.mapserv has no properties"
where "document.mapserv" is the form that's submitted to the mapserver app.
Please check out the following site:
http://geneva/cgi-bin/mapserv?map=/var/www/html/download/mapserv/maps/doqq.m
ap&layers=cntbnd+hydros&mapext=370000+360000+793990.758+59428.989&mode=b
rowse
and its source code, and let me know if you have ideas on remedying this
problem.
Thank you.
Regards,
Christine McCain
Research Assistant
Geoplan / University of FL
