[mapserver-users] Shapefiles
Vinko Vrsalovic B.
v at w.cl
Fri Aug 17 13:10:16 PDT 2001
> Go to the View Menu-->Properties. Set your Map Units then click on Area
> of Interest. The extent will be displayed.
> Ciao!
> Perry
You should also 'Set AOI to:' Display.
> > I would like to try the showextents script however I don't have pearl map
> > script and can't for the life of me find any info on downloading or
> > installing it.
In the mapserver distribution comes a directory called mapscript,
you should cd into that directory, and do a perl Makefile.PL, make, make test,
make install.
V. <v at w.cl>
More information about the MapServer-users
