[mapserver-users] Point Queries Hanging
Ballard,Lowell
LBallard at YesVirginia.org
Tue Aug 21 15:47:46 EDT 2001
MS 3.5 nightly from today
RH 7.1
If you query an area where points are grouped tightly you get the correct
behavior. Poly and line features seem to work ok.
If you click on a point that is somewhat isolated...the server hangs.
Nothing interesting in the apache logs. Saw some related post on the
listserv archive but no resolution.
http://gis.vedp.org/cgi-bin/mapserv35?mode=browse&layer=buildings&layer=coun
ties&layer=spot2001&zoomdir=0&zoomsize=3&imgxy=299.5+250&imgext=174222.22222
1+171734.167340+184098.765431+179972.850473&map=%2Fusr%2Flocal%2Fapache%2Fht
docs%2Fvedp_maps%2Fvedp.map&savequery=true&mapext=shapes&img.x=322&img.y=243
.map layer:
LAYER
NAME buildings
TYPE POINT
DATA bldg
STATUS ON
CLASSITEM "bldg_no"
LABELITEM "bldg_no"
MAXSCALE 100000
LABELMAXSCALE 25000
HEADER buildings_header.html
TOLERANCE 10
CLASS
NAME Buildings
EXPRESSION /./
SYMBOL 'square'
SIZE 5
COLOR 0 0 255
TEMPLATE buildings.html
LABEL
SIZE 8
MINSIZE 2
MAXSIZE 8
COLOR 0 0 0
OFFSET 3 0
BACKGROUNDCOLOR 245 240 219
BACKGROUNDSHADOWSIZE 4 4
BACKGROUNDSHADOWCOLOR 0 0 0
TYPE TRUETYPE
POSITION lr
FONT tahoma
ANTIALIAS
BUFFER 1
END
END
END
Lowell Ballard
Unix/Database Administrator
Virginia Economic Development Partnership
901 E. Byrd St., Richmond, Va. 23218
http://gis.vedp.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010821/8e27c009/attachment.html
