[mapserver-users] More php/mapscript problems under solaris 2.6
    Andries J. Algera
    aalgera at ibama.gov.br
    Tue Aug 21 13:24:15 PDT 2001
I have the following piece of code:
// Open map object
$map = ms_newMapObj("../webmap.map");
// Get the theme descriptions
for ( $i=0 ; $i < $map->numlayers; $i++ ) {
    $l=$map->getLayer($i);
    $tema[$l->group] = $l->getMetadata("title");
When the parser tries to run the line $l=$map->getLayer($i) with $ > 0, I
get the following error:
Fatal error: Object has an invalid _handle_ property in
/home/httpd/webmap/html/webmap.php on line 60
This same piece of code works perfectly fine on my linux server, so I
guess it has something to do with the Solaris version.
If you need more information, please let me know.
Andries Algera
CSR - IBAMA
SAIN L4, Lote 4, Ed. IBAMA Sede
70800.200  Brasilia / DF
BRASIL
ph: +5561 316-1326
          316-1453
fax:+5561 223-7108
More information about the MapServer-users
