[mapserver-users] Problem with layer name?
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Aug 31 10:11:02 EDT 2001
That's more of a recommended limit. There is no hard limit in place for layer name length. The
problem is more likely the '=' after HEADER.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Zhou Xu <zhox at yeah.net> 08/30/01 07:19PM >>>
I think this is the problem:
"Short name for this layer. Limit is 20 characters. This name is the link between the mapfile and web interfaces that refer to this name. They must be identical. The name should be unique, unless one layer replaces another at different scales."
These words come from http://mapserver.gis.umn.edu/doc/mapfile-reference.html#layer,which describes the Name property of Layer.
On 2001-8-30 13:08:00, you wrote:
>Hi all,
>I've got the following layer definition that will not load:
>LAYER
> NAME "03D_GreensBayouPlant-WhiteOakSub_tl_structure_NE"
> TYPE POINT
> STATUS ON
> TOLERANCE 10
> DATA "03D_GreensBayouPlant-WhiteOakSub_tl_structure_NE"
> LABELITEM 'STRUCTUREI'
> CLASS
> name "03D_GreensBayouPlant-WhiteOakSub_tl_structure_NE"
> COLOR 255 255 13
> SIZE 10
> SYMBOL 'triangle'
> END #CLASS
> HEADER = "queries/poles_header.htm"
> QUERY
> TEMPLATE "queries/poles.htm"
> END #QUERY
>END #LAYER
>I read that any non-alphanumeric characters have to be encased in single
>or double quotes; am I missing something above?
>Thanks,
>Mark
>Mark Giesbrecht, M.Sc.
>GIS Programmer/Analyst
>GeoArctic International Services Ltd.
>mgiesbrecht at geoarctic.com http://www.geoarctic.com
>phone: (403) 290-1320 fax: (403) 264-5848
ZiZhuYuan BaishengCun No.1
NGCC
Post Code, 100044
Beijing, China
Phone: +86 10 86851042
Fax: +86 10 68424101
Email: std at nsdi.gov.cn
