[mapserver-users] MapScript and PHP 4.0.6
Rob Martinson
cathode at nichebox.com
Tue Jul 17 23:43:52 PDT 2001
Daniel,
Thank you thank you! Consider this a confirmation to problems with PHP
4.0.6. I backtracked and rebuilt with source from 4.0.5 and I have zero
problems! The issues with losing the handle of the map when dynamically
generating a map from database contents are gone. I can now reliably (it
seems) create a map on a blank .map file using mapscript only to set
map/layer/class properties and add additional layers.
This works now with the CVS version of Mapserver, Gdal and PHP 4.0.5 on
my end.
Rob Martinson
Nichebox - http://www.nichebox.com
Development - http://dev.nichebox.com
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of
> Daniel Morissette
> Sent: Tuesday, July 17, 2001 7:27 PM
> To: mapserver-users
> Subject: [mapserver-users] MapScript and PHP 4.0.6
> Hi Everyone,
> There seems to be an incompatibility between the
> PHP/MapScript module and PHP 4.0.6 which causes crashes or
> odd error situations, most of the time with the
> map->getLayer() call. This happens on both Windows and Unix.
> We are going to look into this, but in the meantime, you
> should avoid using the PHP/MapScript module with PHP 4.0.6
> ... you can use PHP 4.0.4pl1 or 4.0.5 which were both working fine.
> Note that backtracking to older versions of MapServers such
> as 3.4 or 3.3.011 with PHP 4.0.6 is not likely to resolve the problem.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
More information about the MapServer-users
