[mapserver-users] Querying
Vinko Vrsalovic B.
v at w.cl
Thu Jul 26 20:44:48 EDT 2001
Hi again.
I'm getting this error:
Fatal error: Object has an invalid '_map_handle_' property in /file/path
on line 157
and it happens on this line of code:
$l_click->draw($imag);
the l_click layer in the map file is:
LAYER
NAME clicks
TYPE POINT
STATUS ON
DATA theme3
CLASS
NAME "Clicks"
SYMBOL 2
SIZE 8
OUTLINECOLOR 0 0 0
COLOR 255 0 255
LABEL
OUTLINECOLOR 0 0 0
COLOR 0 0 255
SIZE MEDIUM
POSITION AUTO
PARTIALS TRUE
END
END
END
$imag is the return value of $map->prepareImage();
The layer has data added through $l_click->addFeature($shape);
$shape is valid (i write it to a file through a shapefileObj and
I can visualize it in ArcView)
And if I draw a point on the layer through $point->draw(...) it works
too.
What am I doing wrong?
V. <v at w.cl>
