[mapserver-users] Drawing Maps
Daniel Morissette
morissette at dmsolutions.ca
Fri Jul 27 07:55:14 EDT 2001
"Vinko Vrsalovic B." wrote:
> If you're using 3.5 there's a method from the map object called zoompoint,
> here's an example in php, should be easy to port to perl:
Quick note: the zoompoint(), zoomrectangle() and zoomscale() methods are
in PHP/MapScript only and were there in 3.4 as well. They are not
available in the Perl version but they are likely going to be added to
the Perl MapScript by Steve before the 3.5 release.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
