[mapserver-users] Changing feature points
Stepan Kafka
kafka at email.cz
Tue Jun 5 04:21:09 EDT 2001
Remove POINTS section in your map file. (I had similar problem with it and
it helped me.)
Stepan Kafka
> -----Původní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uživatele Mike Law
> Odesláno: 4. června 2001 22:12
> Komu: mapserver-users at lists.gis.umn.edu
> Předmět: [mapserver-users] Changing feature points
> Greetings all,
> I'm having some trouble with the MapServer 3.4 cgi processing a change in
> the point values for a feature object. I've added a form object
> which adds
> the following to the url:
> ...&map_postcode_feature_points=-79.97+43.45&...
> to try and dynamically change the location of the symbol based on
> user input
> (which will eventually be drawn from a database, but that's going to be
> implemented later).
> When it is run (under Apache on Windows), I get a crash in
> MapServer and an
> Internal Server Error sent back from Apache. I've copied the relevant
> section from my .map file below. I'm wondering if there's something that
> I'm doing wrong here. Thanks very much for any help people can give me.
> cheers,
> Mike
> layer
> name "postcode"
> postlabelcache true
> status default
> type point
> class
> symbol "place_ident"
> label
> angle auto
> antialias
> backgroundcolor 255 255 255
> buffer 1
> color 255 255 255
> font "arial"
> force false
> maxsize 9
> mindistance 15
> minfeaturesize auto
> minsize 9
> offset 6 6
> outlinecolor 0 0 0
> position ur
> size 9
> type truetype
> end
> end
> feature
> text "You Live Here!"
> points -79.87 43.25 end
> end
> end
> _________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
