[mapserver-users] enterprise gis
Brent Fraser
bfraser at geoanalytic.com
Wed Jun 6 10:06:50 EDT 2001
Eric (and other MapServer / MapPoint users),
I'm not sure what functionality of MapServer would be of use to MapPoint.
MapServer renders a GIF/TIF/PNG raster map. MapPoint cannot (as far as I
know) import a raster map. With MapPoint 2002, it is possible to import
vector map data (points, lines, polygons) with some programming of
MapPoint's exposed ActiveX interface. If you want to do a spatial select of
store locations, it might be better to store the data in a database as you
suggested and do a little programming to do the extract and post onto
MapPoint.
On the other hand, the automatic route calculation of MapPoint is
interesting (along with the street-level data for Canada). Hmmm, I wonder
if there is a way to get lat/lon route points and driving directions from
MapPoint and pass them to MapServer for display on the web...
Brent Fraser
GeoAnalytic Inc.
#300 , 700 - 4th Avenue SW Calgary, AB
Canada T2P 3J4
Tel: (403)213-2700 Fax: (403)213-2707
www.geoanalytic.com
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, June 06, 2001 6:17 AM
Subject: [mapserver-users] enterprise gis
> List:
> Can mapserver handle maintaining a dataset like
> store locations and then have a separate GIS
> platform at the client like MapPoint? Or would
> you need something like SDE?
> (Or I suppose if it is as simple as store locations
> you could just use mySQL ?)
> Eric
> http://www.MapPoint.com
