[mapserver-users] LabelAngleItem
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Jun 6 12:58:57 PDT 2001
It works in the test suite against 3.4. See the following:
http://maps.dnr.state.mn.us/mapserver_demos/tests/text_angle_and_size/test.html
I've attached the shapefile used in the test for you to try.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "ANDREW WOOLEY" <AWOOLEY at mountainland.org> 06/04/01 02:16PM >>>
Folks,
I am having some trouble getting my text to rotate. I have read bits and pieces on the archive and such and am not able to get it. I have a roads layer that I would like to label, but it is not working.
I am using mapserver 3.4 with gd 1.8 and FreeType support. I have an item called rotate and calc'd all equal to 90 just for testing purposes and it doesn't work. Can someone give some advice on this matter?
Thanks.
Andrew
Andrew Wooley
GIS Operations Manager
Mountainland Association of Governments
Orem, UT
phone: 801.229.3844
fax: 801.229.3801
email: awooley at mountainland.org
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010606/8b2e3b48/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010606/8b2e3b48/attachment-0001.obj>
Desc: dBase 3 database
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010606/8b2e3b48/attachment-0002.obj>
More information about the MapServer-users
