[mapserver-users] install problems (fwd)
teb
teb at mallit.fr.umn.edu
Thu Jun 7 11:55:04 EDT 2001
------------- Begin Forwarded Message -------------
Date: Thu, 07 Jun 2001 08:29:29 -0700
X-Accept-Language: en
MIME-Version: 1.0
To: mapserver-info at lists.gis.umn.edu
Subject: install problems
X-SLUIDL: 1F6BFE5E-4AF711D5-893600C0-F0570AEB
I am having some trouble installing mapserv 3.4 with php
extensions from
source onto a redhat 6.2 box with php-4.0.5 and apache 1.3.20
using the
dso method. Attached is what is happening after make. It looks
as if
there are a series of compile errors.
As I understand it, after make I should have a mapserver
executable that
gets moved to cgi-bin and php_mapscript.so that gets moved to
/usr/local/lib/php/extensions.
I've also tried installing with php-3.0.14 and apache 1.3.12, but
same
problem. For various reasons we don't want to install these
packages
with rpm files. What would be the recommended versions of each
of these
packages and on what linux platform would you recommend.
Thank you,
Paul Smith
pauls at sccwrp.org
------------- End Forwarded Message -------------
#make
#gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_1_8
# mapbits.c -o mapbits.o
# maphash.c -o maphash.o
# mapshape.c -o mapshape.o
# mapxbase.c -o mapxbase.o
# mapparser.c -o mapparser.o
# maplexer.c -o maplexer.o
#maplexer.c: In function `msyylex':
#maplexer.c:1539: warning: `yy_cp' might be used uninitialized in this function
#maplexer.c:1539: warning: `yy_bp' might be used uninitialized in this function
#maplexer.c: At top level:
#maplexer.c:3004: warning: `yyunput' defined but not used
# maptree.c -o maptree.o
# mapsearch.c -o mapsearch.o
# mapstring.c -o mapstring.o
# mapsymbol.c -o mapsymbol.o
#mapsymbol.c: In function `getCharacterSize':
#mapsymbol.c:386: warning: unused variable `error'
#mapsymbol.c:385: warning: unused variable `bbox'
#mapsymbol.c: In function `msDrawShadeSymbol':
#mapsymbol.c:424: warning: unused variable `font'
#mapsymbol.c:423: warning: unused variable `rect'
#mapsymbol.c:422: warning: unused variable `bbox'
#mapsymbol.c: In function `msGetMarkerSize':
#mapsymbol.c:622: warning: unused variable `font'
#mapsymbol.c:621: warning: unused variable `rect'
#mapsymbol.c: In function `msDrawMarkerSymbol':
#mapsymbol.c:689: warning: unused variable `font'
#mapsymbol.c:688: warning: unused variable `rect'
#mapsymbol.c:687: warning: unused variable `bbox'
#mapsymbol.c: At top level:
#mapsymbol.c:384: warning: `getCharacterSize' defined but not used
# mapfile.c -o mapfile.o
# maplegend.c -o maplegend.o
# maputil.c -o maputil.o
#maputil.c: In function `msDrawShapefileLayer':
#maputil.c:1202: warning: assignment discards `const' from pointer target type
# mapscale.c -o mapscale.o
# mapquery.c -o mapquery.o
# maplabel.c -o maplabel.o
#maplabel.c: In function `draw_text':
#maplabel.c:348: warning: unused variable `bbox'
#maplabel.c:347: warning: unused variable `font'
#maplabel.c:347: warning: unused variable `error'
# maperror.c -o maperror.o
# mapprimitive.c -o mapprimitive.o
#mapprimitive.c:709: warning: `get_centroid' defined but not used
# mapproject.c -o mapproject.o
# mapraster.c -o mapraster.o
#mapraster.c: In function `msDrawRasterLayer':
#mapraster.c:1294: warning: assignment discards `const' from pointer target type
#mapraster.c: At top level:
#mapraster.c:1028: warning: `drawGEN' defined but not used
# mapsde.c -o mapsde.o
#c++ -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_1_8
# mapogr.cpp -o mapogr.o
# epplib.c -o epplib.o
#ar rc libmap.a mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapse
#arch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o
# maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o epplib.o
#ranlib libmap.a
# shp2img.c -o shp2img.o
#gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_1_8
# shp2img.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o shp2img
# legend.c -o legend.o
# legend.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o legend
# mapserv.c -o mapserv.o
# cgiutil.c -o cgiutil.o
# mapserv.o cgiutil.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o mapserv
# shptree.c -o shptree.o
#shptree.c: In function `main':
#shptree.c:38: warning: `filename' might be used uninitialized in this function
#shptree.c:40: warning: `byte_order' might be used uninitialized in this function
# shptree.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o shptree
# shptreevis.c -o shptreevis.o
#shptreevis.c: In function `main':
#shptreevis.c:76: warning: unused variable `pabyBuf'
# shptreevis.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o shptreevis
# shptreetst.c -o shptreetst.o
#shptreetst.c: In function `main':
#shptreetst.c:68: warning: `node' might be used uninitialized in this function
# shptreetst.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o shptreetst
# scalebar.c -o scalebar.o
# scalebar.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o scalebar
# sortshp.c -o sortshp.o
# sortshp.o -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm -o sortshp
#touch perlvars
#pwd > perlvars
#echo -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_1_8 >> perlvars
#echo -I. >> perlvars
#echo -L. -lmap -lgd -lpng -lz -ltiff -ljpeg -lm >> perlvars
#cd mapscript/php3; make; cd ../..
#make[1]: Entering directory `/usr/local/src/webmap_server/mapserver/mapscript/php3'
#cc cc -I. -I.. -fpic -O2 -Wall -DCOMPILE_DL=1 -DPHP4 -DUSE_EPPL -DUSE_JPEG -DUSE_TIFF -DUSE_G
#D_1_8 -I/usr/local/src/webmap_server/mapserver -I/usr/local/src/webmap_server/mapserv
#er/../php-4.0.5 -I/usr/local/src/webmap_server/mapserver/../php-4.0.5/dl -I/usr/local/src/webma
#p_server/mapserver/../php-4.0.5/main -I/usr/local/src/webmap_server/mapserver/../php-4.0.5/Zend
# -I/usr/local/src/webmap_server/mapserver/../php-4.0.5/include -I/usr/local/src/webmap_server/m
#apserver/../php-4.0.5/TSRM -I/usr/local/apache/include -c -o php_mapscript_util.o php_mapscript
#_util.c
#cc: cannot specify -o with -c or -S and multiple compilations
#make[1]: *** [php_mapscript_util.o] Error 1
#make[1]: Leaving directory `/usr/local/src/webmap_server/mapserver/mapscript/php3'
