[mapserver-users] compilation problems
emayerus.cs at clearstream.com
Fri Jun 15 05:22:28 EDT 2001
Hi all,
After several attempt to compile Mapscript/Perl on Win98 machine, I decided
to do it on Cygwin 1.3.2.
Compilation is fine except that I have a regex error when running :
$ ./shp2img -m test.map -o test.gif
msLoadMap(): Regular expression error. (\.map$)
The problem is in the call of : regcomp( &re, MS_MAPFILE_EXPR,
REG_EXTENDED¦REG_NOSUB)
Did anyone made mapscript/perl running on WinXX or on Cygwin ??
Thanks for your help,
Eric
Visit us at http://www.clearstream.com
IMPORTANT MESSAGE
Internet communications are not secure and therefore Clearstream International does not
accept legal responsibility for the contents of this message.
The information contained in this e-mail is confidential and may be legally privileged. It is
intended solely for the addressee. If you are not the intended recipient, any disclosure,
copying, distribution or any action taken or omitted to be taken in reliance on it, is
prohibited and may be unlawful. Any views expressed in this e-mail are those of the
individual sender, except where the sender specifically states them to be the views of
Clearstream International or of any of its affiliates or subsidiaries.
END OF DISCLAIMER
