[mapserver-users] dazed & confused (fwd)
teb
teb at mallit.fr.umn.edu
Fri Jun 15 10:54:23 EDT 2001
------------- Begin Forwarded Message -------------
To: "'mapserver-info at lists.gis.umn.edu'" <mapserver-info at lists.gis.umn.edu>
Subject: dazed & confused
Date: Fri, 15 Jun 2001 09:15:59 -0400
MIME-Version: 1.0
Hello,
I am newbie to GIS & Mapserver, I am trying to setup a location based
service application using the ericsson visual net emulator. I have set this
portion up no problem, I can query the emulator and get back an XML message
with lat/long positioning coordinates.
I have setup the mapserver on a winNT box, and have successfully completed
the demo and can query the mapserver via cgi. When I add my map (.gif) that
I used above for the LBS, it does not appear. I get a red block instead,
which could be the default background color. In my temp directory, I can see
each map is being generated, when I display a temp map, there is no picture.
I have tried substituting my .gif in the demo, and replacing the extent with
the .gif extent.
I have tried just to bring up the map using the cgi variable mode=reference,
and also using mode=browse. When I use the mode= reference, I get a red
square, when I use the mode=browse I get the alternate text from the <img
.... > tag.
Can anybody tell me what I am doing wrong?
Here is a copy of my map file
MAP
NAME ATLANTA
STATUS ON
SIZE 250 250
UNITS meters
IMAGECOLOR 9 0 0
EXTENT 742230 3741870 754620 3754070
TRANSPARENT ON
WEB
TEMPLATE /webserver/xitami/webpages/gisdemo/ms_demo/atltemplate.html
IMAGEPATH "/webserver/xitami/temp/"
IMAGEURL "/temp/"
LOG "atl.log"
END
REFERENCE
IMAGE /webserver/xitami/webpages/AtlantaMap.gif
SIZE 250 250
STATUS on
#OUTLINECOLOR 255 250 0
END
LAYER
NAME "GENERAL"
#DATA /webserver/xitami/webpages/AtlantaMap.png
END
END
Chuck Bokath
Air2Web, Inc.
Promenade II
1230 Peachtree Rd
Atlanta, Georgia
+1 404 942 5311
------------- End Forwarded Message -------------
