[mapserver-users] Proj.4
Thorsten Fischer frosch at cs.tu-berlin.de
Sat Jun 16 01:07:20 PDT 2001
Andrew,
> When I do ./configure I send the --with-proj4 flag
> and the output says:
> checking for pj_init in -lproj... yes
>         using PROJ.4 from system libs.
> Yet, it says that I don't have projection support enabled.
> It doesn't seem to matter if I specify the path or not.
When running Linux, you have to add the PATH where your libproj*.so
libraries reside to /etc/ld.so.conf, so programs are able to find
the library at runtime. After adding the path, run /sbin/ldconfig once to
update the system library cache.
thorsten
thorsten fischer
thfischer (at) mapmedia (dot) de
More information about the MapServer-users mailing list
