[mapserver-users] imgbox works on Netscape but not Internet Explorer
Michael Hearne
Michael.Hearne at noaa.gov
Wed Jun 20 07:58:38 EDT 2001
I have a similar, if much less reproducible, problem. I've got one
mapserver app where the 'Pan' mode doesn't work in IE, but 'Zoom Out'
and 'Zoom In' do. Everything works just fine in Netscape.
Is there any difference in the way that IE handles form variables that
would cause this behavior?
"Hockaday, John" wrote:
> Hi all,
> I am using some javascript that sets the imgbox variable after a user drags
> a box
> across the mapserver image. This is then submitted to mapserv. The drag
> box
> seems to work on both Internet Explorer (IE) and Netscape but for some
> reason
> IE seems to pass the img.x and img.y variables to mapserv in the query
> string
> and so, instead of zooming to the defined box (as Netscape does), mapserv
> uses the img.x and img.y values to execute either zoom in, pan or zoom out
> according to which radio button has been selected by the user. Thus
> Netscape
> zooms in to the defined box are but IE zooms in, pans or zooms out.
> Has anyone else observed this problem and if so were you able to solve it?
> I am using MapServer Version 3.3.011 -FreeType -TIFF -EPPL7 -JPEG on a
> Sun Solaris 2.6 UNIX box with Apache 1.3.12 as the web server. The browsers
> are Netscape Communicator 4.77 and Internet Explorer version 5.00.2314.1003.
> My code to set the imgbox is as follows:
> Within the form I have:
> <input type="hidden" name="imgxy" value="">
> <input type="hidden" name="imgbox" value="">
> <input type="hidden" name="imgext" value="[mapext]">
> <input type="hidden" name="map" value="[map]">
> Within the javascript I have:
> document.mapserv.imgxy.value = "";
> document.mapserv.imgbox.value = tx1 + " " + ty1 + " " + tx2 + " " + ty2;
> document.mapserv.submit();
> Thanks for any help or direction that you can give me.
> John
Michael G. Hearne email: Michael.Hearne at noaa.gov
Coastal Remote Sensing phone: 843 740-1281
TPMC/NOAA Coastal Services Center fax: 843 740-1312
2234 S. Hobson Ave., Charleston, SC 29407
