[mapserver-users] Layer description in template file
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Jun 21 10:41:24 EDT 2001
In 3.4 and lower versions the [layername_desc] is available as a replacement only if the
layer has been explicitly turned on. Otherwise it gets a blank string. The reasoning is that
this was used as a way to provide alternate titles and such in an interface based on what
is actually display. If a layer is off then we don't want to see the infomation. Note that default
layers are not explictly on (i.e. the user didn't choose them) and display with a blank string.
In 3.5 description goes away in favor of a generic metadata object that is much more flexible.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Berend Veldkamp <berend.veldkamp at aris.nl> 06/21/01 09:38AM >>>
Anyone knows how to get the description of a layer in the template?
[layername_desc] seems to be replaced with an empty string.
Berend
_________________________________________________
ARIS - Hooghiemstraplein 126 - NL 3514 AZ Utrecht
tel. +31 30 2769180 - fax. +31 30 2733578
URL: http://www.aris.nl/
