[mapserver-users] query tiled data
Paul Hastings
paul at tei.or.th
Thu Jun 21 11:31:18 PDT 2001
yes, to my shame (blamed on poor eyesight & the docs recentness)
found them on the docs page though even these docs & ms3.5 aren't
quite synched (the tile "bug").
i also noticed the 3.5 (win32, CGI) spits out quite a bit of debug info,
i don't suppose there's a switch to turn these off (not asking for one,
just asking if one already exists)? make parsing templates w/cf a bit
harder.
thanks.
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <mapserver-users at lists.gis.umn.edu>; <paul at tei.or.th>
Sent: Friday, June 22, 2001 12:20 AM
Subject: Re: [mapserver-users] query tiled data
3.5 introduces full support for query of tiled data, older versions do not.
3.5 HOWTO documents
are creeping into the documentation section already. Installation and map
file guides are there
already with MapScript and a couple others following shortly.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Paul Hastings <paul at tei.or.th> 06/20/01 07:59AM >>>
is it possible to point & click query tiled data with ms3.3
or ms3.4 (nt/cgi)? i think the MAP syntax is correct (below)
but i can't seem to find anything.
btw are there any docs lying around for ms3.5? doesn't
seem to be much in the mail archives.... thanks.
LAYER
NAME "Geology"
TILEINDEX "index250k"
TILEITEM "Location"
STATUS DEFAULT
TYPE polygon
MAXSCALE 3000000
MINSCALE 50000
LABELITEM "SYMBOL"
LABELMAXSCALE 3000000
LABELMINSCALE 50000
LABELCACHE ON
CLASS
NAME "Geology"
COLOR 150 150 150
OUTLINECOLOR 252 250 205
LABEL
MINFEATURESIZE 20
COLOR 1 1 1
END
END
TOLERANCEUNITS meters
TOLERANCE 50
QUERY
TEMPLATE "queryGeology.html"
END
END
Paul Hastings paul at tei.or.th
Director Environmental Information Center
Thailand Environment Institute
Member Team Allaire
http://www.tei.or.th/eic ---------------------------
More information about the MapServer-users
