[mapserver-users] PROJ support for Lambert Azimuthal Equal-Area
Ed McNierney
ed at topozone.com
Wed Jun 27 15:30:25 EDT 2001
Folks -
I'm trying to work with the USGS's shaded relief raster image of North
America, and I'm having some trouble with it. The raster base map is
described (in its metadata) as a Lambert Azimuthal Equal-Area
projection, with a central meridian of 100W and a central latitude of
45N. If I load this into ArcView 3.2a (after creating a custom
projection to meet these specs) I can load the raster image and a simple
US state outline (lat/lon) on top of it and they register correctly.
If I try to do the same thing in MapServer 3.4, the state outlines
appear generally to be projected correctly, but the entire layer is
translated just about due north by some distance, so the states lie up
in the Canadian Arctic.
Has anyone used PROJ.4 for LAEA projection? Any ideas or thoughts would
be very much appreciated. The map file is below, and you can see the
application (just a quick-and-dirty hack to show the problem) at
http://140.239.90.197/NationalAtlas
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
(978) 251-4242
NAME NationalAtlas.map
SIZE 600 600
EXTENT -6003377.0 -3271289.0 5239501.0 2011590.0
UNITS meters
SYMBOLSET symbols/symbols.sym
IMAGECOLOR 255 255 255
WEB
TEMPLATE 'NationalAtlas.html'
IMAGEPATH 'S:\MapServer\NationalAtlas\tmp\'
IMAGEURL '/NationalAtlas/tmp/'
END #WEB
PROJECTION
"proj=laea"
"lon_0=100w"
"lat_1=45n"
"datum=NAD83"
END
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE SMALL
END #LABEL
SIZE 350 5
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 255 255 255
UNITS kilometers
INTERVALS 10
STATUS ON
END #SCALEBAR
# Start of layer definitions
LAYER
NAME 'ShadedRelief'
TYPE Raster
STATUS On
DATA 'D:\NationalAtlas\ShdRlfI020L8-1.TIF'
END
LAYER
NAME 'Counties'
TYPE Polygon
STATUS On
DATA 'D:\NationalAtlas\CountyP020'
CLASS
OUTLINECOLOR 255 127 0
END
PROJECTION
geographic
END
END
LAYER
NAME 'States'
TYPE Polygon
STATUS On
DATA 'D:\NationalAtlas\StatesP020'
CLASS
OUTLINECOLOR 127 0 0
END
PROJECTION
geographic
END
END
END # MAPFILE
