Problems with the Zoom Function of the PHP MapScript Module
Christian Fuerpasz
fuerp at atlas.gis.univie.ac.at
Wed Mar 7 04:53:17 EST 2001
Hello everybody!
In my Application there appears a problem in the Zoom Function in one
special Case, otherwise it works correct.
I use the Mapserver 3.3.011, PHP Mapscript from DM Solutions and also
the the Rosa Applet.
When i use the zoom function it works almost correctly. I can use it by
a single click or by drawing a Rectangle. Its not allowed to zoom in
more then specified in the .map file. But this works only in the middle
of the Map.
When you use the Zoom Button and Zoom in with drawing a small rectangle
very near the border of the Map i get a map in the bigest scale (which
should be correct) but with the Mapextends outside the specified
extends.
Now i can see the background which should never be seen. When i use now
the pan function in this black (from me in the .map file defined)
background the map is replaced correctly so that the border of the map
is the border of the image.
In all other Functions the Zoom Function works correctly.
I think the Solution of this Problem can found in the PHP Map Script
but I
would be happy if you can give me some hints to develop a fast solution.
An other Problem with the ROSA Applet is, that if you draw a Rectangle
and
first Click in the Map than move the mouse outside the Map and than
release
the Mouse Button you will get a Map which should not been drawn in this
way. I
tried to correct this, by setting the coordinates of the maxx and maxy
to the
maxextends of the Map but than I could suddenly zoom in over the given
Min
Scale which should also not appear.
Also in this Point I hope to get some help from you.
Thank you for your time.
With best regards
Christian Fuerpasz
________________________________________________________
Institut fuer Geographie der Universitaet Wien
Kartografie und Geoinformation
Deptartment of Geography and Regional Science
University of Vienna
Cartography and GIS
Tel: (+43 1) 4277 48658
Fax: (+43 1) 4277 48649
E-Mail: mailto:fuerp at atlas.gis.univie.ac.at
Snail-Mail: Universitaetstr. 7, A-1010 Wien, AUSTRIA
WWW: http://www.gis.univie.ac.at/karto/
