Problems with the Zoom Function of the PHP MapScript Module
    Doyon, Jean-Francois
    Jean-Francois.Doyon at CCRS.NRCan.gc.ca
    Wed Mar  7 06:22:41 PST 2001
This sounds like a problem I found a while ago with that version of
MapServer, it was giving me
head aches at the poles and so on ... I would suggest you download the
latest version
and give it a try, if the problem is the same , it was fixed soon after
3.3.011 ...
J.F.
> From: 	Christian Fuerpasz[SMTP:fuerp at atlas.gis.univie.ac.at]
> Sent: 	Wednesday, March 07, 2001 4:53 AM
> To: 	Mapserver
> Subject: 	Problems with the Zoom Function of the PHP MapScript Module
> Hello everybody!
> In my  Application there appears a problem in the Zoom Function in one
> special Case, otherwise it  works  correct.
> I use the Mapserver 3.3.011, PHP Mapscript from DM Solutions and also
> the the Rosa Applet.
> When i use the zoom function it works almost correctly. I can use it by
> a single click or by drawing a Rectangle. Its not allowed to zoom in
> more then specified in the .map file. But this works only in the middle
> of the Map.
> When you use the Zoom Button and Zoom in with drawing a small rectangle
> very near the border of the Map i get a map in the bigest scale (which
> should be correct) but with the Mapextends outside the specified
> extends.
> Now i can see the background which should never be seen. When i use now
> the pan function in this black (from me in the .map file defined)
> background the map is replaced correctly so that the border of the map
> is the border of the image.
> In all other Functions the Zoom Function works correctly.
> I think the Solution of this "Problem" can found in the PHP Map Script
> but I
> would be happy if you can give me some hints to develop a fast solution.
> An other Problem with the ROSA Applet is, that if you draw a Rectangle
> and
> first Click in the Map than move the mouse outside the Map and than
> release
> the Mouse Button you will get a Map which should not been drawn in this
> way. I
> tried to correct this, by setting the coordinates of the maxx and maxy
> to the
> maxextends of the Map but than I could suddenly zoom in over the given
> Min
> Scale which should also not appear.
> Also in this Point I hope to get some help from you.
> Thank you for your time.
> With best regards
> Christian Fuerpasz
> ________________________________________________________
> Institut fuer Geographie der Universitaet Wien
>    Kartografie und Geoinformation
> Deptartment of Geography and Regional Science
>    University of Vienna
>    Cartography and GIS
>   Tel:            (+43 1) 4277 48658
>   Fax:            (+43 1) 4277 48649
>   E-Mail:       mailto:fuerp at atlas.gis.univie.ac.at
>   Snail-Mail: Universitaetstr. 7, A-1010 Wien, AUSTRIA
>   WWW:        http://www.gis.univie.ac.at/karto/
More information about the MapServer-users
