Some help about MapScript
Daniel Morissette
morissette at dmsolutions.ca
Sun Mar 25 21:01:14 EST 2001
Sebastien,
The SHADESET problem must be because you have the demo for version
3.3.011 but you try to use it with a version 3.4 executable, see the
following message from the archive about the symbol changes between
version 3.3.011 and 3.4:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0102/msg00179.html
and about the PHP MapScript configure problem, see:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0102/msg00134.html
Daniel
Sebastien 'Tito' Cazajous wrote:
> Hi,
> i am trying to install the MapServer demo, i haven't got trouble to
> compile
> the cgi prog and install it but once this works i try to make the
> MapServer
> demo working, i get the demo_readme.html file to get into the MapServer
> world
> i make the modification on my Debian Box but after all this manipulation
> i run the demo in my browser and i get an unreferenced error:
> "msLoadMap(): Unknown identifier.(SHADESET):(6)"
> I suppose that is an initialization problem but i am not able to find it
> is someone able to give me a little help.
> Moreover i try to compile the MapScript Php module, i compile
> php-4.0.4pl1 right and
> get a DSO for Apache, then i put the current path of my php compilation
> source
> files and i try to run the configure MapServer Script it find the
> correct
> information but it doesn t generate the MapScript/PHP Makefile
> creating Makefile
> sed: file conftest.s1 line 74: Unterminated `s' command
> creating gdft/Makefile
> creating mapscript/php3/Makefile
> But any makefile is generated...
> Do you have same thing trying to do this...
> Best Rgds, Tito
> +--- \\\// ------------ # Sebastien 'Tito' Cazajous # ---------+
> | (0 -) # sebastien.cazajous at eiKonex.net - www.eiKonex.net # |
> +-oOO--(_)--OOo-----f0ll0W thE wHitE pEngUin-thE LinuX has U-----+
Daniel Morissette morissette at dmsolutions.ca
http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
