[mapserver-users] UTM projection
Thorsten Fischer
thfischer at mapmedia.de
Thu May 3 07:41:38 EDT 2001
Hi list,
I am using the mapserver in a smoothly working CGI application, similar to the
official example. It lets Netscape display a simple 'document contains no
data' window after I made a change in projection.
I have a .map file with roughly the following content:
<header>
PROJECTION
"proj=merc"
"ellps=sphere"
END
LAYER
PROJECTION
"geographic"
"ellps=WGS84"
END
END
<lotsa more layers>
which works as it is supposed to. For some reasons, I have to switch the
projection over to UTM, which I thought would be done by replacing the
projection field with:
PROJECTION
"proj=utm" # projection
"ellps=GRS80" # or whatever ellipsoid seems to fit
"zone=32" # we are in germany
"north" # northern hemisphere
"no_defs" # ?
END
Please bear with me because I am not a cartographer. According to the usual
lists germany is UTM zone 32, and I do not know what 'no_defs' means.
The extents are set correctly (they do not differ much from the mercator
projection, which, as far as I understand these things, is of no surprise).
What am I doing wrong?
On a completely unrelated note, it would me nice to have the syntax of the
.map file's setions unified. I think it would be preferable to have
something like
PROJECTION
TYPE merc
ZONE 32
END
instead of the syntax you all know about, which may be easier to pass to a call
of the proj library without parsing but which is confusing the user (some of
ours at least).
Greetings from the sun-flooded places of northern Berlin,
Thorsten
Thorsten Fischer thfischer at mapmedia.de
MapMedia - Kartographie und raumbezogene Informationssysteme
Am Borsigturm 42
13507 Berlin
Deutschland
http://www.mapmedia.de tel: +49 (0)30 43032102
