[mapserver-users] html link in the demo
david clough
davidclough at ntlworld.com
Fri May 4 18:34:14 EDT 2001
probably a rela simple answer , but i am new to this . I would like an html
link to be displayed in the query page. linking to a html based reports
in the example i downloaded this page would be lakespy2 - so unser the line
that returns area perimeter , usclass of the lake there would be another
line with a link to maybe pdf or and html reports
I hae tried adding a col to the dbf file, however it tells me the <a href>
is not permitted within the dbf file
many thanks for anybody who can help a newbie
david clough
cambridge
england
uk
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of Stephen
Lime
Sent: 04 May 2001 16:31
To: andreag at crs4.it; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] problems from 3.4 to 3.5
The error you're getting refers to a change in metadata support. 3.4 and
earlier versions really provided no metadata support other than the layer
DESCRIPTION field. That has been replaced with a general METADATA
tag that can be used for lots of things. One example is that WMS
compatabilty
requires metadata to produce a capabilties document. So rather than adding
a new field for each possible WMS need a generic solution was added.
As a result the LAYER DECRIPTION tag is gone. You can now do something
like:
LAYER
NAME "lake"
METADATA
description "!:24,000 USGS DLG Lakes Data"
author "USGS"
END
END
I still need to make these data available as template substitutions though.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "A. Giacomelli" <andreag at crs4.it> 05/04/01 05:30AM >>>
I am porting an application developed in php/mapscript from an
installation using
MapScript Version (Jan 8, 2001)
MapServer Version 3.4 (pre-release) -GD_1_2 -PROJ.4 -FreeType -TIFF
-EPPL7 -OGR
to
MapScript Version (Apr 3, 2001)
MapServer Version 3.5 (pre-alpha) OUTPUT=GIF INPUT=SHAPEFILE
(as read from phpinfo on the two machines)
Should I expect any problems ?
As a matter of fact, I am getting an error on the Rosa demo application:
Warning: MapServer Error in loadLayer(): (DESCRIPTION):(88) in
/usr/local/apache/htdocs/sard/gmap/htdocs/gmap75.php
on line 51
Fatal error: Failed to open map file gmap75.map in
/usr/local/apache/htdocs/sard/gmap/htdocs/gmap75.php on line 51
TIA for any suggestion,
Andrea Giacomelli
Centre for Advanced Studies, Research and
Development in Sardinia
Environment Group
http://www.crs4.it/~andreag
