[mapserver-users] mapserver problem (fwd)
Chris Stuber
imap at chesapeake.net
Fri May 18 14:48:23 EDT 2001
Venkat,
I suggest that you download Shapelib
at http://gdal.velocet.ca/projects/shapelib/index.html
and use 'shpdump <shpfile> |more '. The first thing it spits
out is the extent of the shapefile. Over the years I
have found the tool to be invaluable and I use it all the
time (thanks Frank).
Regards,
Chris Stuber (mapsurfer)
> teb wrote:
> ------------- Begin Forwarded Message -------------
> From: "A.Venkatesan" <venkat at kar.nic.in>
> To: <mapserver-info at lists.gis.umn.edu>
> Subject: mapserver problem
> Date: Fri, 18 May 2001 19:14:30 +0530
> MIME-Version: 1.0
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
> Dear Friend,
> I installed mapserver s/w yesterday and downloaded demo progs
> also. Everything works ok with demo. I tried to include one of my
> shape files as a layer and it is not displaying. In order to
> verify the problem, I used jshape applet to display ctybdpy2
> which is one of the shape files in the demo directory. This file
> did not display where as my shape file displayed in jshape. I
> made the mapscale parameter in jshape to 1 and then the
> demo-shape file displayed. With this I presumed that the EXTENT
> definition may have something to do with the problem. I am not
> able to find the way to give extent values for my shape file. Can
> U Pl help?
> Thanks in advance.
> Regards
> Venkat
> ------------- End Forwarded Message -------------
> Dear Friend,
> I installed mapserver s/w yesterday and downloaded demo progs also. Everything
> works ok with demo. I tried to include one of my shape files as a layer and it
> is not displaying. In order to verify the problem, I used jshape applet to
> display ctybdpy2 which is one of the shape files in the demo directory. This
> file did not display where as my shape file displayed in jshape. I made the
> mapscale parameter in jshape to 1 and then the demo-shape file displayed. With
> this I presumed that the EXTENT definition may have something to do with the
> problem. I am not able to find the way to give extent values for my shape
> file. Can U Pl help?
> Thanks in advance.
> Regards
> Venkat
