[mapserver-users] labelitem and filteritem
    Stephen Lime
    steve.lime at dnr.state.mn.us
    Mon Nov  5 10:32:02 PST 2001
Without seeing the whole application it's tough to diagnose the problem. There are
lot's of places this could go wrong including the source code I can't speculate.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> toni hernández <toni at giscampus.udg.es> 11/05/01 01:35AM >>>
HI,
well, I already have the itemquery mode and still isn't working.
I tried to put the FILTERITEM, FILTER and LABELITEM in another layer and the
result is the same, I mean if FILTERITEM and FILTER appear in the map file
as well as LABELITEM (the three tags in the same layer) then LABELITEM has
no effect at all.
Any idea?
----- Original Message -----
To: toni hernández <toni at giscampus.udg.es>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, November 02, 2001 5:04 PM
Subject: RE: [mapserver-users] labelitem and filteritem
> At 12:18 PM 11/2/2001 +0100, you wrote:
> >Hi All,
> >Does anyone on the list know why I cann't use both labelitem and
filteritem
> >at the same time with CGI 3.5?
> >If I use filteritem, the tag labelitem has no effect at all and if I
detele
> >the labelitem tag then I can use filteritem with no problem
> >Does it have any sense?
> I may not understand your question, but anyway - You can use both
labelitem
> and filteritem, but filteritem works with an itemquery, so if you are not
> in itemquery mode, no results wiil be found, and hence nothing will be
labeled.
> Richard W. Greenwood, PLS
> Greenwood Mapping, Inc.
> Rich at GreenwoodMap.com
> (307) 733-0203
> http://www.GreenwoodMap.com
More information about the MapServer-users
