[mapserver-users] server error
Müller Ulrich
Ulrich.Mueller at bd.so.ch
Tue Nov 6 08:41:26 EST 2001
I am facing three situations when I get an INTERNAL SERVER ERROR message. In
two cases I have no idea what's the reason. In the third case I found a
solution, but it is probably still worth mentioning.
My detailed description follows below. Thanks for your advices!
Uli Müller
Kanton Solothurn
GIS Koordinationsstelle
Rötihof
CH-4509 Solothurn
T: +41 (032) 627 2475
________________________________________________________________
1) I try to load a dgn file with the following Mapfile entries:
LAYER
NAME samp15
STATUS ON
TYPE LINE
CONNECTIONTYPE OGR
CONNECTION
"/opt/wwwroot/sogis/develop/umue/MapServer/daten/cad/samp15.dgn, 0"
END
The file is a sample from the DGNLib website, so it should be ok. I can also
view it in our Desktop GIS ArcView without any problems.
MapServer version:
3.4 and 3.5
apache error log entries:
msOGRLayerOpen(/opt/wwwroot/sogis/develop/umue/MapServer/daten/cad/samp15.dg
n, 0)...
msOGRLayerClose(/opt/wwwroot/sogis/develop/umue/MapServer/daten/cad/samp15.d
gn, 0).
* malformed header from script. Bad header=Found deleted, skipping.:
/opt/wwwroot/cgi-bin/sogis/ms_ogr
2) I want to query a numeric field of a polyline-shape. The query normally
works fine. However I get the server error, when
- I zoom in to a scale larger 1:1000, and when
- I change the tolerance to a value different from 0
The mapfile looks like this:
LAYER
NAME gshiso
MAXSCALE 600000
STATUS ON
TOLERANCE 5
DATA aww/gewaesserschutzkarte/gshiso
TYPE LINE
LABELITEM "Kote"
QUERYITEM "KOTE"
SYMBOLSCALE 10000
LABELMAXSCALE 25000
CLASS
COLOR 0 62 210
SYMBOL 2
SIZE 2
LABEL
TYPE TRUETYPE
ANTIALIAS
FONT arial
COLOR 0 0 0
OUTLINECOLOR 255 255 230
SIZE 8
MINSIZE 4
MAXSIZE 11
ANGLE AUTO
POSITION CC
MINFEATURESIZE AUTO
END
END
QUERY
TEMPLATE
"/opt/wwwroot/sogis/develop/umue/MapServer/projekte/aww/gws_karte/qry_tpl.ht
ml"
END
END
MapServer version:
3.3
* Premature end of script headers:
/opt/wwwroot/cgi-bin/sogis/mapserv
3) I want to display a polygon shapefile. It works fine at large scales. I
get the server error message, when I zoom out below 1:300000. However the
error disappears completely, when I move this layer at the bottom of the
mapfile. As soon as another polygon layer is drawn below the problem layer,
MapServer crahses.
For this problem I found a possible reason. My shapefile had some very small
polygons (digitizing errors). After deleting the corresponding records,
everything worked at every scale and for every layer combination. Still,
MapServer should not crash with small polygons?
The mapfile:
LAYER
NAME holoz
TYPE polygon
STATUS ON
TRANSFORM true
DATA 'aww/geologie/blatt34/holoz'
CLASSITEM 'FORMATION'
CLASS
NAME 'Postglazial'
EXPRESSION '421421'
COLOR 105 105 105
SYMBOL 7
SIZE 3
END # CLASS
END
MapServer version:
3.3
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011106/f54a4957/ISO-8859-1QMFCller_Ulrich2Evcf.obj
