[mapserver-users] drawQuery and draw bug?
Jim Burnett
jimburnett at ntelos.net
Tue Nov 6 14:44:48 EST 2001
I have two functions one that uses drawquery and the other that uses just the draw functions.
If I used the draw(), and draw a map it looks fine, if I change the draw() to drawquery(), then the map looks all choppy...is this a bug? The only thing I am changing is the draw() function. The reason I am asking, is because my drawQueries all look choppy.
It seems that if you use drawQuery, it uses the default map sizes instead of what you set them with $mapobj->set("width",400); etc etc.
-jim-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011106/ea05e62e/attachment.html
