[mapserver-users] getSymbol() error (was: Re: Problems with PHP/Mapscript)
Daniel Morissette
morissette at dmsolutions.ca
Tue Nov 6 13:39:29 EST 2001
Greg Liapis wrote:
> Warning: MapServer Error in getSymbol(): (Points):(5) in /path/to/Greece.php on line 5
> Fatal error: Failed to open map file /path/to/Greece.map in /path/to/Greece.php on line 5
Greg,
This error is related to a recent change made by Steve to the syntax of
the FILLED and ANTIALIAS symbol and label parameters. See item#3 in the
following archive message:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0110/msg00374.html
As you (and other users) upgrade to the latest 3.5 CVS version, you need
to change all occurences of FILLED and ANTIALIAS in your mapfiles and
symbol files to add a TRUE or FALSE value following the keyword.
e.g.
Symbol
Name 'circle'
Type ELLIPSE
Filled
Points
1 1
END
END
becomes
Symbol
Name 'circle'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
