[mapserver-users] Problems with nightly / cvs compile
Daniel Morissette
morissette at dmsolutions.ca
Wed Nov 7 07:26:28 EST 2001
Tim Sutton wrote:
> I am trying to compile the mapserver with php_mapscript from last
> night (06/11/2001). I get the following error from both CVS and
> nightly tar build attempts:
> php_mapscript.c: In function `php3_ms_img_saveImage':
> php_mapscript.c:3914: warning: implicit declaration of function
> `php_header'
> I had a look in the file mentioned above to see if I could work it
> out, but I couldnt...can anyone help me out here?
This is just a warning which has been there since we started supporting
PHP4 and shouldn't really affect your build. Yes I should fix it, but
you can safely ignore it. If your build doesn't work then it is likely
something else.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
