[mapserver-users] Compiling gd with freetype2 on Solaris 2.6
Daniel Morissette
morissette at dmsolutions.ca
Wed Nov 14 00:03:54 EST 2001
"Hockaday, John" wrote:
> This seems to have worked however after I compile mapserver I get the
> following error when I run mapserv:
> "$ ./mapserv
> ld.so.1: ./mapserv: fatal: libfreetype.so.6: open failed: No such file or
> directory
> Killed"
> The /usr/local/lib/libfreetype.so.6 file exists.
The file exists but probably isn't in your runtime library path... see
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0110/msg00340.html
for a discussion of a few solutions to this problem.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
