[mapserver-users] QUERYONLY?
Obe, Regina DND\MIS
Regina.Obe.PFD at ci.boston.ma.us
Wed Nov 14 17:27:30 EST 2001
I got a similar error too (not sure if these two are related) - using the
mapserv35_png_ogr for win32 build 11/7/2001. This was using the itasca demo
app for 3.5 (I downloaded 10/17/2001) (and my other apps which worked with
prior version of the mapserv 3.5 exe also give similar behavior. So I was
wondering if an interim change to specs had taken place during the 3.5
between 10/19 and now.
The prior version I was using was a build around 10/19/2001.
I get an error
getSymbol(): Symbol definition error. (END):(96)
(I did modify it a bit to work with my configuration so not the exact demo -
but just minor changes to paths)
When trying to use the itasca demo app - dated around 10/17/2001
-----Original Message-----
Sent: Wednesday, November 14, 2001 11:29 AM
To: steve.lime at dnr.state.mn.us
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] QUERYONLY?
> It's STATUS QUERY, not QUERYONLY.
also tried that, but:
Warning: MapServer Error in getSymbol(): (QUERY):(64)
LAYER
NAME buses
METADATA
"DESCRIPTON" "Rec Buses"
"RESULT_FIELDS" "ROUTE_ID"
END <---------------------------------------- Line 64
STATUS QUERY
TYPE LINE
LABELITEM "NOMBRE"
DATA r_bus_utm56
CLASS
NAME "Rec Buses"
TEMPLATE "test_draw_map.phtml"
LABEL
COLOR 238 238 140
FONT arial_V
TYPE truetype
ANGLE AUTO
ANTIALIAS
SIZE 7
END
COLOR 200 150 54
END
TOLERANCE 10
END
V. <v at w.cl>
